There's a blue LED light on my Galaxy S5 that wont turn off! How do I turn it off?
  • Start date Start date
A
AC Question
There's a blue LED light on my S5 that's been on constantly since yesterday. I had LiteFlow installed, but I uninstalled it because I've heard there are issues.
I pulled the battery and I've restarted the phone. Nothing seems to make it go away. The light comes on as soon as i put the battery back in, before the phone is even turned on.
It's driving me nuts! please help!
Julia
Re: There's a blue LED light on my Galaxy S5 that wont turn off!
Go to settings> display>led indicator.
You must have an undead text, or email or missed call that was over looked. Good luck hope it helped!
Posted from the commode, thanks to Samsung Galaxy S5a.
There are no active notifications either. No texts, email, missed calls,, Thanks though!
Did you uncheck them and out stayed on?
You could download light flow from the app store, check and uncheck until your light goes off so you know what the problem is.
Thanks, I tried that - still nothing. In fact, when I test the LED selections the blue light stays on between the flashes of the other colours.
I'd call for a replacement lol.
I called Samsung and the best they could do was tell me to restart it in safe mode. Thanks for your help!
Call your carrier
There's nothing wrong just a voice mail or notification
I've had this issue for a month now. Few times it goes off when I do some things and shows a small "disabled" icon at the bottom.
Julia
I just had the same problem. A light blue LED was stuck on constantly for weeks. I just replaced the battery with a new one and once I turned the phone on, to my excitement, the LED was off!
Hope this.helps albeit belated :/
Julia
aaronr
