- Jun 6, 2010
- 139
- 1
- 0
My main reason for wanting to hard reset is memory related--I keep getting the 'Low on space' notification, even though I think I have relatively few apps all together compared to what it seems many others users have, and of those I do have I have, every one that allows me to do so is copied to the SD card. The notification appears whenever I get to about 88-89% used (+/-42MB remaining). I have cleared the cache and soft reset repeatedly with the same result. What's so frustrating about this is, whenever the 'Low on space' notification appears, my Google account will not sync at all (not even manually).
All that said, I am presently getting the notification off and on constantly (mostly on)...and my calendar is totally jacked--some of my calendars sync, some partially sync, and some don't sync at all, even when I do not have the notification (yes, they are all set to sync). So I am hoping that a hard reset will get me back on track and fix whatever is causing the memory and related (I think) sync issues.
If I do a hard reset, all my previously downloaded apps (paid and free) be restored when I visit the Market? Will all my apps currently on the SD card remain unaffected?
Any other help, advice and/or suggestions are welcome...
Thanks!
ME
Thanks!
ME
