Titanium Backup Pro Key Problem
Mar 25, 2013
12
Hello. I have an ATT HTC One fully rooted and functioning fine. I recently upgraded to Trickdroid 11 and with my Titanium backup Pro key, I was able to restore my apps much faster after a full wipe. Yesterday, I flashed Omni ROM which is a simply AOSP ROM with Cyanogen base. I performed full wipe, flashed the ROM and correct gapps and everything was fine. First thing I do is install Titanium Backup (TB from here on out). I realize that I dont have the Pro key installed (although this was never a problem before, it would just somehow have the pro key even after full wipe). But this time, it said I did not have pro key. I go into Google Play and try to install it (as I have already bought it months before and have used it since) and it will not download saying "error 403." I was annoyed so I reflashed my backup of Trickdroid 11 and looked on it and somehow my TB pro was gone on it as well. The only difference there is that Google play says that it is installed. I tried restoring the backed up TB pro key and that did not work either. I really want to use this new ROM as it has multi-window support but I do not want to manually install all of my apps again with the non paid version of TB and I do not want to have spent the $7 for nothing.
All thoughts and suggestions are very much appreciated.
Thanks in advance.
Thanks in advance.
By chance do you still have the email about the purchase?
From a Sprint Moto X using AC forums app
Welcome to the forums.
Are you still having the 403 problem?
Here's a thread with 3 post about the issue and a solution that has worked on the home network - uncheck the "proxy filter" or "filter cookies" option on your home router (assuming the errors are occurring while trying to download and install through your home network.
I am on a college network so that isnt an option. Also, Everything else from the play store downloads. It is ONLY TB pro key that wont.
marksains61
