Total Commander NTFS exFAT plugin copying and pasting files problem
everway9
211
Hi all. :)
I've installed the Paragon NTFS exFAT plugin for Total Commander on my Galaxy Note 8 and can't for the life of me work out how to do a simple file copy and paste. It is probably just me but it seems pretty complicated.
I'd like to copy a file from my NTFS USB flash drive to the SD card in my Note 8. Nothing seems straightforward about it.
If anyone is familiar with this software please can you help?
Many thanks in advance. :)
Find the flash drive (probably Drive A). Find the file. Long-press it. Copy. Find the place you want to copy it. There should be a paste button upper right if I remember).
Hi Rukbat.
Sorry for my late reply.
Thank you for your post.
I can long press on a file and a menu pops up and i then selected 'copy to clipboard' (which was the only copy option) but when I go to the location I want to paste the file in I cannot find any paste button anywhere. I've tried dragging the file from window to window but that doesn't work either.
It would be nice if there was a proper copy and paste option like with pretty much every other file explorer software. It's probably easy when you know how. :(
guyuynhfrd
