Totally lost need help.
BomBerS
5
I installed the unofficial gingerbread release for my DroidX and now I would like to get the official one but i'm having trouble finding a solid thread that shows me how to do this, when it comes to android I have no idea what I am doing is there anyone willing to give me a hand out there?
I found a few with guides and all but they don't seem to work I can't get RSD Lite to recognize my phone and I don't have the option for it to run as administrator on windows vista.
As far as the technical terms and abreviations that I need to know I also am clueless. I just want to run the official because the one im running now is acting funny and I would like an official release to hopefully aleviate some of these problems.
Any help is greatly appreciated
Thanks!
Alright thanks for the help, i'm trying to get RSD Lite to install on my laptop right now and i'm going to give that a shot again if not i'm out of ideas...
UPDATE: I finally got RSD Lite working on the laptop i'm install the factory froyo skb on it right now and will just do the ota update for gingerbread hopefully it all works! Thanks for the help guys!
Is it possible to change themes I noticed that people are posting pictures of their screens and are totally different if so is there any good websites recommended for them?
Well I installed the sbk file and now my phone doesn't do anything but show the main loading screen. this is silly.
Finally got it working did a factory reset after I installed the sbk file for gingerbread
Sent from my DROIDX using Tapatalk
Here is how i updated- from stock Froyo- root with z4.
Download D2bootstrapper from market.
Download 2 file method for gingerbread from that above link.
Rename files so you can see part 1 or 2 near beginning of name.
Place files on sd card.
Run d2bootstrapper- click Bootstrap recovery- when says success click reboot recovery
When in recovery mode- use volume keys scroll to install zip from sd- press camera to select.
Scroll again to install zip from sd and select
Install part 1.
Install part 2 before rebooting.
then reboot system.
... hope that helps you
Well its already done but thanks for the help and quick responds
chrisra
