Touch vibrations and lock sound stopped working
docgoat1987
153
7
With the ics update i dont know if anyone has experienced this my screen lock sound is lower then it used to be even with system volume all the way up
Also just now my touch vibrations like got softer almost as if itwas shut off so i restarted my phone and it started to work weird huh
Sent from my Nexus S 4G using Android Central Forums
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
If the reboot fixed it then great! Keep an eye on it, it is possible that if it continues you may have to do a factory reset if things keep acting strange after the ICS update.
Reactions: docgoat1987
hlxanthus
1,790
411
Switching to a new operating system does not always go off without a hitch. Sometimes settings get wonky due to some app or its data. If you are running stock and not rooted, I would perform a factory reset and start from scratch. Back up all data you can first though like SMS pictures etc.
Sent from my Nexus S 4G using Tapatalk 2
Lilc73
