• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Transformer TF701 stuck at bootup - Urgent Help needed
spiderbatman
Hi,
I have a Asus Transformer TF701. I was using it and it was out of power. So I plugged it in and now it is stuck at boot up.
Even if I force it to shutdown (long press power button) it again starts and gets stuck at boot up.
I need help desperately as to how can I resolve this problem. Please help.
Thanks in advance.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,923
275
83
Welcome to Android Central! After powering down, try powering up again by pressing and holding the Power and Volume Up buttons--keep them down until some kind of recovery menu appears. If that doesn't work, try Power and Volume Down.
AndroidProf
303
Let me elaborate on that, this will open the bootloader menu. Once in that menu, look for the option that says "Factory Reset" and a "Wipe Cache" option. You can navigate the menu by pressing the volume keys. Also, do remember by doing this you will be wiping your Asus Transformer CLEAR of all personal data that is stored in the internal memory of the tablet! If that doesn't help and you are still stuck in a bootloop, I'm sorry to say but then you will have to flash in a new ROM on your device. For that you will need a custom recovery (I suggest TWRP, you can Google TWRP and go to the first link and just find the recovery for your device, they even teach you how to install the recovery). Once you have done that, you can find a custom ROM for your device or even the factory image online on XDA developers, Clockwork Mod, CyanogenMod or searching for the factory image (the default ROM). You can download the ROM and flash in via the custom Recovery by going to the bootloader again (Restart while holding Vol. Down) Then selecting Go to Recovery Menu (pressing Power + Vol Up once the exclamation sign appears, alternatively if you have any experience with how to use adb you can simply use "adb reboot recovery" as well). From there, simply flash in the ROM from the "Install via .zip file".
