Trying to fix not using default tones for specific people...
McDiddles
Hey all! I was messing around with my Galaxy S3 and tried to put specific notification tones for certain people in my contacts list. But just as I was getting used to the pace of doing it all I accidentally hit "Always" instead of "Just Once" on the default tones and now it will no longer let me choose a notification tone for people. I use Zedge and that's where my ringtone/notification tones are from but it no longer pops up when I'm in a contact's name as a choice. When I look at the tones in the general settings it's there. Is there anyway I can get it back to give me the option between default and Zedge?
Also I've tried clearing the defaults on Zedge itself in Application Manager but it just keeps saying "No Defaults Are Set". Thanks for any help!
Simple to fix!
1) Drag down the notification bar from the top of the screen, or just press the venter menu bar on the bottom of the phone
2) Tap on the "cog" wheel on the top right
3) Scroll down, and tap on Application Manager
4) Scroll down and tap on Zedge
5) Scroll down and Where you see Launch by default, you will see Clear defaults beneath that. Tap it, and back out all the way and you're done and can again use the inherent ringtone selector from the OS!
Good Luck, and Aloha!
I've tried this before and it only says "No Defaults Are Set" :/
OK, then have you done this:
go to settings>Application manager
Change to the "all" screen
It opens to the "Downloaded" screen as a default there is "running" on the right of that and "all" to the right of "running"
scroll down to "Media Storage" and clear defaults there too.
theantithesis
