Turbo Charging vs. Wireless Qi Charging
rxgadget
730
3
Anyone know difference between the 2 on a normal basis yet?
What about Qi vs normal wall charger
Sent from my SCH-I535 using Tapatalk
Just got my qi charger. Got a Nexcon® Qi Enabled Wireless Charger Inductive Charging Pad Station from Amazon for $14. Did a quick test. Phone charged from 75% to 94% in 1 hour. That's about what I was expecting. I'm planning to use the qi charging at night, so I can just put the phone on it when I go to bed.
The charging coil is in the lower half of the phone. The phone will display an image telling you to line it up with your charger when it detects a qi charger near by.
I don't have a case yet. I'll post once
I get one. The charger I got says 4-10mm distance so it should
I have 3 Qi chargers and have not even used the Turbo Charger yet. If I do I will be sure to comment on the differences.
Posted from my Droid Turbo via the AC App
Got my case today. It is just the silicone cover that Verizon sells. it is pretty thin. But my Qi charging doesn't work with the case on. Maybe a better charger would. I just bought the cheap "Nexcon® Qi Enabled Wireless Charger Inductive Charging Pad Station for All Qi Standard Compatible Devices" from Amazon to try it out. I'm not really worried about it at this point but did want to share my findings.
A qi charger can work through an otterbox
It must be the charger because the Tylt Vu worked on my Droid Maxx with a Diztronic case on it and others reported it with Otter box.
Sent from my Motorola Droid Turbo
I do not have a turbo, but both my DNA and nexus 7 charge when they are in their cases. I use Nokia Qi chargers.
