Two problems i'm having...
mitch2k12
60
The first is with the alarm clock. It never works. This morning, I had it set for 9:05, and I randomly woke up at 9 and waited anyway to see if it would go off, since I had been having problems, and sure enough, it didnt. But it does work if i set it 5 minutes from now....
The other problem is when i click on a chat with *for example* my friend chase, sometimes it takes me to a different chat with my friend collin. So i go back, and then try it again and it will work. but its very weird...
Do you have a task killer installed? If you do you have to exclude the clock from the applications that get killed.
[/QUOTE] The other problem is when i click on a chat with *for example* my friend chase, sometimes it takes me to a different chat with my friend collin. So i go back, and then try it again and it will work. but its very weird...[/QUOTE]
This happens to me every now and then. I dont know what causes it or a fix for it. I just back out and go into the correct one.
Thanks everyone, the task killer was the problem, and i hope htc will fix the message error.
Richie Q
