Two things I am having problems with ...(Sywpe, and Handcent problems)
hybridboy695
16
1. I am using swpye and when it puts up a different word from what I want I used to be able to double tap the word and choose the right one. Now when I double tap it puts up a stock cut copy paste option over the swype box. Is there any way I can turn this off?
2. I use handcent and some of my contacts are saying they are receiving my text messages three times. Does anyone have this problem and how do I fix this?
I may can help with # 1...no clue on #2
1. to correct a word, just tap the word, then the lower left key (Swype S) and your word choices pop up. Also, it was said that the double tap rate (how fast you double tap) can distinguish if the choices come up vs copy/paste. I guess i'm just slow. I couldn't figure it out.
Try Go SMS Pro for your text messaging program. I switched over to thta from Handcent.
I read somewhere about the multiple message issue. I had the same problem one day and a shut down and restart of my TB seemed to fix the problem. I haven't had it a second time.
You need to use a longer tap to just get the word choice. Instead of tap-tap, do tap(pause)tap. That will bring up the word choice but not the copy/paste option.
isaackse
