A
Android Central Question
Hello everyone.
As the title says, I have Ulefone Power 3 (running Android 7.1.1) and manually installed Android Auto.
However, it is impossible to connect it to VW RCD330+ radio using wired USB connection - the devices simply don't pair up.
Is there anything what can be done to troubleshoot or make deeper investigation of the issue?
From what I have read online, wired (via USB) Android Auto should work almost on all devices, meanwhile for wireless there is a set of only certain models.
Thank you!
Thank you!
