Ultra Power Saving Mode
Apr 29, 2014
16
Hi All,
Just getting to grips with the S5 and need some assistance please.
I love the idea of the Ultra Power Saving Mode but is there any way of configuring it to automatically kick in when your battery level reaches 10%? So far it seems like you've got to manually enable it which seems a bit odd.
Thanks
Hi All,
Thanks
That'd be freakn awesome, but nope no mods made for it.... yet ;)
Sent from a Galaxy 5 light years away
They said at the launch that it would kick in at 10%, but so fare I haven't seen anything to allow it..
I activate Ultra Power Saving when I'm done using the phone all the time. Its the best feature on the s5.
Thanks for your reply's.
I can confirm this mode definitely does not kick in once the battery hit's 10% which is a shame :-(.
My only issue with this mode is the amount of time it takes to load up. When switching between normal and Ultra Power Saving it takes a good 10-15 seconds but if it increases my battery life by 12-24hrs I can't complain.
linercapr
