Unable to establish a wireless data connection
Abbers727
372
18
I get this pop up sometimes when I turn off my wifi.
It says 'unable to establish a wireless data connection'
I was wondering if there was a setting I needed to change or something before I go to a sprint store to try to fix the issue. Screenshot_20180622-085018_Samsung%20Experience%20Home.jpg
Turn on mobile data before turning off wifi. If mobile data is off and you turn off wifi, there's nothing left that's turned on.
I always have mobile data on. Should I turn off the Wifi power saving mode?
dkpiper
