unable to reboot into stock after flash it using enxus 4 toolkit!need help
Chuck Ni
after i have tried several custom roms, i found out that the stock android is best for me, so i decided to flash my device to stock. i believed i have followed every instruction in the toolkit, and everything seems fine until it finished flashing. The command says the it is rebooting, but my device wont roboot and is still in the fastboot mode.so i tried to manually roboot it,and it reboot right back into my old paranoid Andoird version. It is so weird !!!!Does everyone have the same problem or just me? Can anybody help me out? i really appreciate it .
I would try redownloading the ROM again and reflashing. See if that helps.
How are you trying to flash it? Through ODIN or recovery?
OP says in the title he's using Nexus 4 Toolkit...
@Chuck Ni - Give the Nexus Root Toolkit by WugFresh a try. Everyone says it's top shelf and I've found it a pleasure to work with for GNex and N4. Pro Tip: Wug's toolkit seems to flash best from a file off your desktop so download a fresh copy of 4.2.2 here. It will also restore root for you and install TWRP recovery.
do you know how to flash factory image using ADB?? best way to flash stock is ADB.
the factory image has stock recovery,radio and the OS.
Edit: I meant fastboot
Fastboot, not adb, and never Odin a Nexus device.
OP check t factory image restore guide in the Rooting section.
No members online now.
brucestark2741
