Unlock problem
Vinh Le
4
I use to have to drag an icon to unlock my phone, now I just have to touch anywhere on the screen and it will unlock
It realy annoying, ie I listen to music, press the fwd button, it do nothing and the pattern unlock screen appear.
I can't scroll to check my message or calendar anymore, it will try to unlock and I'll get the pattern screen.
How can I restore the default
Thank
You can always do a factory reset (last option). But have you checked settings, security, and screen lock?
Sent from my HTC One using Tapatalk 2
Check do you have any apps enabled in the accessibility section. When I have certain apps enabled there my lock screen does the same thing.
Think this is a known problem and 4.1. I had the same issue when using notifer pro etc.
Since update to 4.2.2 seems to be resolved
Js42FL
