UnRoot Thunderbolt - HBOOT Problem
durtle4
6
While rooted and continues when unrooted:
Following screen comes up but will NOT allow VOL UP or VOL DOWN but instead jumps to what must be recover by first looking for PG05DIAG.ZIP which it does not locate and then goes to PG05IMG to update.
Happens over and over and over. How do I recover ability to use volume rocker for choices? The phone seems to work okay, except that Navigation app isn't connecting for what must be some other reason. HELP, PLEASE, HELP.
MECHA XD SHIP S-ON
HBOOT-1.04.0000
MICROP-/
RADIO-1.16.00.0223r
eMMC-boot
Feb 23 2011, 20:42:55
HBOOT
<VOL UP> to previous item
<VOL DOWN> to next item
<POWER> to select item
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
HBOOT USB
IMAGE CRC
Can also be replied to at durtle4colsoh@gmail.com
I just want to get TBolt back to factory condition for now.
Did u try putting PG05DIAG.zip back in the root directory of ur SD card. Sounds like its boot looping looking for the file....
Sent from my ADR6400L using Tapatalk
Reactions: jimnycricket65
Cannot locate even with Google
Thanks so much for the reply. I never saw a zip with this name at the beginning of all this, and Google isn't hitting on one either. If anyone has a copy, I'd love one cause I assume things won't change without it. Otherwise, the phone works fine.
If anyone has a copy, please link or email. Would like to get that last detail taken care of.
Thanks! durtle4colsoh@gmail.com
XDA Dev Same problem - no replies
Found this post at XDA but no replies.
Originally Posted by gadsden
Ok, I'm flashing it again. Is it normal for the bootloader to say:
loading....PG05DIAG.zip
not found
loading....PG05DIAG.nbh
not found
loading...PG05IMG.zip
Then it loads the .zip
Edit to add: It didn't reboot again. I'm scared to go forward because of it, I might go back a step and make sure everything is ok.
Ok, I just noticed something else during the flash. When it says Parsing sd zip, item [7] TP results are "bypassed" Is that a problem, or is it normal?
So again, if anyone has copy of zip to add to SD, please, please, please share.
Durtle that file sounds vaguely familiar. I would head to the few methods of the supposed "one click" rooting methods that have come out recently. In the instructions they tell you to download quite a few files before you start and there are links to them. U may find what you are looking for there.
not found
not found
yeah, that's normal. What it's doing is looking for specific file names and PG05IMG is the one you want it to use.
One more problem...
The other problem I had in unrooting was I couldn't get to SU:
To begin, extract the Unrooting kit to any folder and rename the stock firmware to PG05IMG.zip.
Copy the firmware to the root of your SD card.
Now run command prompt on your pc and enter the following commands, hitting enter after each command:
adb push misc.img /data/local/
adb push busybox /data/local/
adb shell chmod 777 /data/local/busybox
adb shell
su (came back permission denied).
Could the HBoot be a problem because of this? Maybe best to root again and then unroot?
Your help is appreciated! Thanks.
Do "Exploits" vary?
One more quick question... following various instructions, I've loaded Exploits.zip from a couple different places but they all seem the same inside. Are they?
Thanks again. This has all been very interesting.
Should be the same assuming you got it from one of the rooting guides. Just remember to extract the contents of the .zip the desired folder on your computer.
Thanks so much - one more for unrooting...
Thanks so much for the help received. I decided to do one more root (which now went really well). The script I followed did the following in the root stream:
To push the eng bootloader:
adb push hbooteng.nb0 /data/local/
Now we will write the new bootloader.
dd if=/data/local/hbooteng.nb0 of=/dev/block/mmcblk0p18
Is this the reason that vol up/down for Factory Reset, etc. for not working but does directly to looking for, and reloading the image on the SD card?
The instructions for unroot say nothing about bootloader, they are:
First, download the following files:
Stock firmware (MD5 sum: 7141f5620f6128af77d50587e341f4b0)
exploits.zip (MD5 sum: 3b359efd76aac456ba7fb0d6972de3af)
Next, push busybox and misc.img.
To gain root and flash misc.img:
adb shell
su
/data/local/busybox md5sum /data/local/misc.img
If the output is anything other than ?c88dd947eb3b36eec90503a3525ae0de,? stop and start over again.
Now let?s write misc.img:
dd if=/data/local/misc.img of=/dev/block/mmcblk0p17
Rename ?PG05IMG_Mecha_VERIZON_WWE_1.12.605.6_Radio_1.16.00.0223r_NV_8k_1.41_9k_1.64_
release_174685_signed.zip? to ?PG05IMG.zip? before placing it on your SD card.
Finally, reboot into bootloadermode byentering the following command. Allow the stock firmware to flash.
adb reboot bootloader
You?re done ? your phone should now be stock, S-ON.
So bottom line - should bootloader be replaced to original? what is the correct line command?
the eng bootloader is what allows us to get s-off. During the root process, we flash the stock 1.12.605.6 RUU minus the bootloader. The 605.6 RUU that's used for the unrooting process includes the bootloader so it gets rid of the engineering one. Or at least I think that's how it goes. lol
I am dealing with the same issue. I am getting forced close when trying to use pandora and can get gps to show my location but time settings think I'm in Rio. Trying to flash back to stock and get super user denied. boot loader is at:
Mecha XD Eng s-off
h-boot 1.04.2000 PG0510000
microp-/
radio 1.02.00.0103.2r
emmc-boot
feb 23 2011 20:36:02
Superuser works when using apps such a tether.
What to do next? re-root in case I missed a step?
Update:
I didn't realize had spoiled I had become with my HTC Incredible. I down loaded rom manager and flashed CWR. Flash a customer rom and all is now good. Won't have to worry about being back to stock at this time.
its actually pretty fast unlike the filefactory version which doesnt even work with my phone. right now i can flash items and lock and unlock the bootloader, but i get a flashing boot animation no matter what OS i flash over. it could be stock, TSGB, Lightning ROM, or and SDK from google that has nothing on it. i actually dont know what happened. i didnt do anything to it but restart. EVERYTHING works except the OS actually loading.
:'( when i loaded my backup that worked 100 times before, the white boot logo showed up and stayed there for 2 hours. my backup only took 10 minutes to restore plus 2 minutes of loading time to settle. i think i accidently deleted the settings storage.apk on my phone, but the recovery should have restored that. i just cant figure out why it wont finish loading after looking at ALL the forums available in a 5 day span. can anyone help me with that? it should be mostly relevant to this post.
MECHA XD SHIP S-ON
HBOOT-1.04.0000
MICROP-/
RADIO-1.16.00.0223r
eMMC-boot
HBOOT
FASTBOOT
RECOVERY
FACTORY RESET
SIMLOCK
HBOOT USB
IMAGE CRC
The best and easiest method is the ALL IN ONE...that will take your phone back to 100% stock......09 software revision. Should take about 15 mins.
What "all in one"?
Can't factory reset. Ph98img.zip Update fails...Please help.
Have PH98IMG.zip on sd card. Gets this far...
*** LOCKED *** VIGOR PVT SHIP S-ON RL HBOOT-2.11.0000 eMMC-boot
HBOOOT Parsing...[SD ZIP]
[1]... ...[18] ... start update? <VOL UP>
Next to "[1] BOOTLOADER" "- Fail-PU" And below [18]..., "Partition update fail!" "Update Fail!" "Press <POWER> to reboot."
It's an HTC Rezound I'm trying to get back to stock, Verizon.
Any ideas?
Help77
