Upgrading to S25 Ultra, should I move SD card Data to internal memory before using smart switch?
Pecas1961
Smart switch should take care fo that for you, but since the newer phone has no SD card, be careful with filling up internal memory with SD card files. Also, since the SD Card is no longer supported, if you have any apps that were set to run from the card in the older phone, these will be moved to internal memory, which may cause issues with apps that have 'hard coded' path files (since the app would be looking for a folder in an SD Card directory that no longer exists).
That being said, data transfer from internal memory is faster than from a card with a lot less chances of the transfer failing (SD cards can be finicky, especially when extended data transfer sessions are involved)
Reactions: Laura Knotek
Crusher
