Upload speed issues?
ac295
73
Bought my Rezound last night and love it.
I'm getting blazing fast download speeds, like 30mb on 4g and where my PC is getting 16mb on a WiFi connect my Rezound is pulling closer to 20mb sitting right next to it.
However, using the same WiFi connect my PC pulls 9mb upload speeds and my Rezound is either puttering around the 1-2 mb range or barely finishesthetest ataround 0.
Same with 4g connection, and I'm using speedtest.net as well as Speakeasy just to make sure.
Is this a common issue? I need to know if i have a problem with the device now so I can exchange it as soon as possible.
Thanks!
Thanks!
It's not really an issue so much as a problem with the way the phones and speed tests are designed. Do some real world testing and see if the problem still holds true. Upload some huge pictures to flickr or something and time how long it takes.
^Good stuff. That's been my experience w/ my ups. Can't depend on tested speeds to be truly accurate. I've even seen better up #s, than down #s, on occasion, which took me for a loop.
Thanks for the response, but it def was the device. I returned it and it is no longer a problem. Swapped out for a brand new one.
* edit
Spoke too soon. This phone is acting the same way. Strange.
nickmeredith
