USB C Charging cable recommendation
encelle111
127
Thanks to a 6 month old yellow lab puppy, I need to replace my usbc to usbc cable. Any recommendations from Amazon that would ensure I can take advantage of rapid charge? Thanks
Aukey or Anker same/better quality as OEM and much better price so you can often get an extra spare one and still save a couple of quid
I have both brands mentioned and I couldn't recommend any other ..they are solid choices ..
Thanks. I was just unsure if any USB C to USB C cord is fine to get maximum charging speed or whether you need certain specs.
There is a certain standard you need for the 45W charger, I can't remember what it is called though.
If it matters much for the 25W im not sure
I love my JSAUX cables. They have reinforced ends that really help with failure rates and come I. Super long lengths as well. They can be found on amazon
Yazzy
