USB-C to USB Adapter/Cable
uncaged74
96
A few days ago I learned how you can use that USB-C to USB adapter which I am currently using to type this from an actual keyboard and mouse (not Bluetooth mind you) but using the USB adapter for the peripherals into the adapter and boom you basically have a computer. The thing is, by design of the adapter and my case, the adapter doesn't fit unless I take it out of the case. So what I am looking for is the adapter concept but more of a cable design about 6 inches in length at most. I Google and yet to find what I am looking for.
In case you are not sure what I am speaking of, here is the video.
https://youtu.be/S_iM22JY2y0
Not sure if they exist or not (since the adapter comes in the box I haven't searched for one in ages). Samsung used to sell these for micro-USB before they started including the adapter in the box for device transfer. You're looking for OTG USB-C cables. If they exist, that's how they'd come up in your search at your favorite store.
I believe what you are looking is available in eBay. Search for "USB-C Type C Male to USB 3.0 Female OTG"
Just make sure the keyword OTG is present. Otherwise you're just getting an extension cable.
I got one of these from Amazon. I'll see if I can get the model number for you.
The Amazon app won't let me copy text so I'll just write it out.
LighningKid USB C to USB 3.0 OTG cable. It was only $8.00 and worked great. I've used it with a Nexus 5X and my S8.
rose1988
