USB Charging Cable
Rizy7
638
Im finding the usb cable that comes with the device a little bit on the short side. Does anyone know how long the cable is and could anyone recommend any longer usb cables that work. Im guessing any micro usb cable should work?
EDIT
So I'm using a usb extender now and the phone keeps switching between AC and USB.. Is this safe?
Any micro USB cable should work. I'm currently using the one that it came with, but I've also used my old HTC Evo's cable/charger and my Moto Photon's cable (in the car) with no problems.
I have been using the usb cable that came with my nexus 10. It reaches my bed perfectly
I have so many Micro USB cables now I couldn't even tell you which one came with which device. They all work as long as they're plugged in :D
whiteraice
