usb charging problem
sleepyrey
67
I have a problem wit my phone every time I charge it on my computer it doesn't even charge !!! Am using bamf 1.10
Thanks
Its possible that the port on your computer can't provide enough power to charge it. If it charges ok in a wall outlet that's more then likely your problem
Thanks
I have had that problem on my PC at work. It is an older one and sometimes when I plug my Tbolt it, it gives me an error.
Also, I have a USB cable at work and another one at home. The one at home is loose when I plug it in directly to my phone. But when I plug it into the docking station....works perfectly and fits snuggly. Make sure the cable plugs in tight and doesnt' easily fall out
jimmyrichard
