I just got a Note 3 last night... loving it but I am having a weird USB connection issue. If I have it plugged into my computer through USB and I tilt it a certain way, it tends to reconnect. It gets kind of annoying when I am trying to use it at the computer and it kind of scares me if I want to transfer files to it because it also seems to do it a couple times within a few seconds after the screen goes to sleep. I have to hold the phone perfectly still and keep the screen on to prevent it.
I have tried different ports and I am using the stock cable... is it possible my cable has a short or is it some weird setting with the phone being tilted? Thanks in advance.
EDIT: Also, it sometimes goes into "installer mode" when I plug it in even if I have previously selected media device. I read turning off USB debugging can fix it but it still does it every so often.
