Question USB connectivity problem
nieke_
4
Hi,
I have a USB connection problem.
I first noticed it when I bought a new car, with Android Auto. I have to connect my phone by wire, but nothing happens. Other phones work just fine.
Then I found out that my phone also does not connect to my pc (macbook) and also does not connect to my chromebook. I switched cables and USB-ports, but nothing works.
I don't get a notification to ask me what kind connection I would like: data/midi/... and also there is no notification in my drop down menu.
When I connect any wire to any port in my car/macbook/chromebook my phone charges, but it doesn't seem to recognize a computer.
Does anyone have a solution?
Thanks!
Nieke
I have a: Google one plus Nord N10 5g
With OS: Android 11
#edit: I tried turning it off and on again many times
Are you plugging into a data port or power port in your car?
Have you tried to connect to a windows computer?
Thank you for your replay.
I only have 1 port in my car and when I connect another phone to it, it starts android auto immediately. (So I guess it is a data port)
No I don't have a windows computer, so I can't try it.
Reactions: methodman89
Bride96
