USB Driver problems
VincentShift
Recently, I downloaded new drivers for my phone to connect to my computer via USB to view my files and such.
One day, I wake up, drivers are invalid. Re-download drivers, still don't work. Help?
Look at the bottom of post number 2 in this link, reference section, item D1.
http://forums.androidcentral.com/lg...ls670zvd-zvh-100-automated-zvj-automated.html
Get the drivers from there. Make sure you go into add/remove programs and uninstall what you have on your PC first, then reinstall these. If it still doesn't work after that, restart the computer and double check to make sure you have usb debbuging enabled and then try plugging the phone in again.
Reactions: hlxanthus
Did everything you said, still nothing. I actually do not have a switch for Mass Storage like I did before...But I did try turning off/on my debugging, and still no hope.
When you plug your phone into your computer, does it at least charge? Even without the drivers the pc should still recognize that something has been plugged into it.
arvelljathen
