USB mass storage help?
janina437
So i just got my samsung galaxy S blaze 4g and i wanted to download music onto it. But i have to turn on the USB mass storage so i tried to connect storage to PC but when i do, it says i have to connect the USB cable then when i connect the cable, it says "USB is connected. Remove the cable" then i remove it, then it says i have to connect it and it just goes like a circle. So i don't understand what i'm supposed to do. Please help? Thank you!
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
I agree with a previous post suggesting to download and install Samsung drivers to your PC. Google it, should be easy to find. Otherwise, if you have a removable SD card, it may be easier to load the music files from your pc on an adaptor card.
