USB OTG problem
mdewey1138
6
I have a rooted nexus 7. I installed stickmount but am still unable to see my usb stick.
Please advise.
Mike
Please advise.
Mike
Is stick mount listed as a root app when you open up the SuperUser or SuperSU app?
If not then you missed the prompt that first popped up when you ran stickmount where it requested root access.
If you don't have the superuser app then you may not have rooted
How are you trying to access the usb device? It's only browseable via a file manager, it's not available to other apps as i understand it. Meaning if you throw your music there I don't believe the music app will know to look on the USB device for your files to index. I could be wrong about that.
I checked my SU app. Stickmount isnt listed. I uninstalled it, but didnt get the pop up requesting root access. Now what?
when you use a filemanager can you browse to /sdcard/usbStorage/xxxx/
I believe that is where the usb stick gets mounted to
Please advise.
Mike
Are you sure the otg cable is working. I have read that some day otg but do not work.
From my Galaxy Note 2 via Tapatalk
Try plugging a usb mouse or wireless mouse receiver and see if the mouse works. If not, you may have a non-compatible OTG-usb cable. Some just don't work.
RichardDixon
