Usb power connection flashing
BigSWils
8
Hello i need help i keep getting a usb power connection icon flashing up on my lg g5 and i have totaly reset the phone to factory settings and it still pops up constantly. Please does any body no how to get rid of it please and also my phone does not fast charge no more since this as been happening.
Hi. Did u do battery pull?
What do you meen by did i do a battery pull? If you meen did i disconnect my baterry from the module then yes?
I had something similar a while back. The phone keep claiming to be connected to a charger and then not connected. The sound of he USB plugged in was driving me insane (short trip). This happened regardless of whether it was actually connected or not.
For me the fix was to take the plastic cap of a pen (any thin plastic should work) and used it to make sure that the USB port was clean and nothing was there to cause it to short out. I had to make sure that every side of the little nub was clear of debris. I found this on some site that indicated some phones collected just enough grease or dried condensation in the port to make it short out.
Hey, I had the same problem and turned out the bottom piece was a bit wet. It's a very sensitive part. The fix for me was getting the phone into a rice bowl overnight. It's been working fine for three days now.
Cheers mate i forgot to put down mine also got wet now my gps doesnt work my front face camera doesnt work and fast charging dowsnt work. I have ordered a new bottom module to see if this fix my problems
Ertiotka
