- Feb 10, 2013
- 7
- 0
- 0
Why is it so difficult to find a good car charger! A lot of them out there don't have enough AMPs to do the job and charge 2 devices at once.
I found one though that works really good, the CHOETECH Qualcomm Quick Charge 3.0 & USB C Ports in Dual USB Car Charger. I really recommend it as it has a Quick charge port and a mix of USB and USB C Type ports. Very practical to charge 2 devices with different ports at the same time and fast.
So if you need a good car charger that charges fast and fits perfectly in the car slot, then buy this one!
