use the same LTE sim for GS3 and iphone 4s? is it possible?
dalvik
1,131
62
Hi guys. Just bought an iPhone 4s and thinking to use both devices by switching the same sim. So the question is. Does anyone know if the sim with the LTE plan on it will work on 4S? I really don't want to make any changes on my account
Thanks!
yes it will work technically as both are mirco SIM cards but you may have issues with some iPhone services that need to be specifically added to your account if you have an iPhone. If you have used the GS3 in LTE coverage I suspect you will be unhappy with the bandwidth of H+ on the iPhone4.
I used to do this before i purchased my 5. Keep your account on the GS3 LTE data plan as it will work just fine with the iphone 4s. If you have the iphone data plan the data services on your gs3 wont work. I hate apple for switching to a nano sim, as i enjoy using both devices. My iphone 5 now Serves me well as an ipod touch since the s3 is my daily driver.
Good luck!
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Nehasingh12
