Totally forgot about that. I would do that actually. Then you dont have to go thru the hassle of flashing recovery back n forth and the rom. I say do what Kraven has said. Sounds like a good idea.There's that force flash vd, but it uses command prompts.
dont do it... if anything reboot ur pc and try the mobile update tool again.the phone is asking to install system update
I dont think u can do the OTA on that rom... so I would suggest you use the update tool. You need to reboot tho. Your phone now recognizes that it needs the VD baseband.. thats a good signthe phone is asking to install system update
added:
which lables it as LS670CVD
