I thought I heard that there is a way you can use Google Voice visual voice mail for messages received through you your regular cell number? Some kind of forwarding process? Can someone walk me through this? Am I totally off base here? Thanks!
is there a way to undo this? I use my GV number for my business and I don't want my personal calls going to my GV voicemail
Will the person calling get your Verizon voicemail greeting or the one from GoogleVoice?
Hm I see what you did... is that my only option as a workaround? There's no way to separate the two like I can't have my Verizon number and my Verizon voicemail and have my Google number with my Google voicemail?
I would prefer not to have my voicemails forwarded to Google voicemail.
To use both voice mails and keep them seperate I set up Gvoice (via pc) to handle only the calls going to my Gvoice phone number. But here's the beauty part, you can set it up so the people who call the Google number will ring your VZW number and they will not be able to identify your VZW number. If you don't accept the call and they choose to leave you a message you can view the message through the visual voice mail via your Gvoice account. Note, VZW charges you for this feature. Also, if you're getting calls from anyone you don't want to talk to, you can go in to your Gvoice settings to block their calls and automatically direct them to your Gvoice mail with a custom message of your choice. How cool is that!
I just went in to my Gvoice settings to check into your options. I see there is a way for you to deactivate your Google Voicemail on you cell. On your pc go in to your Google settings, >Select the Phones tab, >Right under your Google Voice Number is the Forwards to: Your Cell Number, >Just to the right of your Cell Number is a clickable Deactivate Google voicemail on this phone, >click on the phrase. You should be able to have Google Voice release it's hold on your voice mail to calls placed directly to your cell phone number.
Hope this helps!
