Verizon G900V USB cable connection problems - PC and Honda Pairing
Steve_Karl
74
Hi there,
My friend has a G900V and it used to connect to my PC in the past, not as easily as my G900A but it was do able.
Just recently the problem with the G900V is that it shows in "Computer" but I'm no longer able to see the "Card" and "Phone" icons inside of SAMSUNG-SM-G900V.
The G900V also doesn't pop up the permissions messages on the phone the same way the G900A does.
The G900V just pops up the "what do you want to do" icon on the PC.
On the PC issue I'm using the same cable as used to successfully connect the G900A.
Next:
Pairing to a 2018 Honda CRV trying to get navigation working on the Honda display.
We get the error message in the attached screen shot:
I'm suspecting something needs changed in the settings on the phone to allow USB connections to other devices but I have no idea where to look to change it.
Can some one please advise me on what to do?
Thank you!
Steve
Steve_Karl
74
Sorry it took so long but you were correct. It was not set to MTP, it was set to "Charging".
I changed it to MTP and it's connecting to PC now.
Thanks for the help!
