Verizon LG G2 - Daydream and Wireless Charging Problems
trivor
373
29
28
One of the many things I loved about the G2 was the built in wireless charging. I bought one of the Nokia Chargers from ATT store ($24.99) and for the first few weeks it worked fine. Then I noticed that it wouldn't charge up overnight. It turns out I started using the Daydream lock widget that was activated any time it was being charged. When I turned that off it worked fine - wasn't really essential anyway.
i am new to the LG G2, I bought a pair.
my problem is charging in the car or with "anyone elses charger"
i get the notification use the official charger
or it barely charges.
does disabling the daydream make it charge better?
Yeah, turn off Daydream, it does slow down the charging. I use the Tom Tom dual USB + extra 12v port charger on the fast charge USB port with an old Samsung micro USB cable and it works fine...with fast charge. It's the only extra cable I have that works with fast charge though, but the rest I had were really old.
