Verizon LG G2 - led colors?
recDNA
8,745
135
63
How many different led notifications colors can you produce. Can they be on when screen is on or only when screen off? Have you tried with light flow?
Thanks!
Sent from my DROID RAZR HD using Tapatalk 2
If you go into a contact (or your calendar) you can customize the color of the notification light for calls or missed events and you have a choice of:
Green
Pink
Blue
Orange
Yellow
Turquoise
Purple
Red
Lime
Pretty good choices and I'm sure Light Flo (or similar app) would let you access them all (there is also a choice for kind of a rainbow light).
Don't remember the exact # but using light flow I was able to get just about every color I tried. 8+ colors at least.
Hope that helps.
Chauncey the Gardener
