And thats exactly how it should be charged, without any thought. We shouldnt have to worry about using any specific charger. I however feel the heat generated by the turbo charger will eventually cause battery problems. Maybe I am wrong but we wont know for at least a year. I usually keep phones for two years so I want it to last at least that long. Battery university showed pretty clearly heat for lithium ion batteries is not a good thing. I will use the turbo charger if I absolutely need to but otherwise I use a couple of old blackberry chargers and most of the house uses apple so chargers are always around.I was just asking because this is the first I've heard of such a thing, and I've had my Turbo for about a month, just using it and charging it whenever possible without any forethought. I also charge it overnight, given I've been told it that has no adverse effects.
I've only ever really charged it using the Turbo charger as well. Would I do better to use another charger?
Cracking me up man!!! And I havent seen you post anything that wasnt helpful. Threres about 4 or 5 posters here that pretty much post the same general ideas and all usually very helpful. I consider you to be in that group. I always carefully read what you and they post in the hopes of learning something. Thanks for the shout out though I appreciate it.EDIT: Foiled by mobrules posting something stellar seconds before me! j/k Yeah, listen to mobrules, much more specific and helpful.
