Verizon Note 5 LED Notification light = Half Blue/Red ?
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
22
38
I've noticed on a new Verizon Note 5 that the LED Notification light sometimes looks like Blue & Red mixed together. :p
Anyone else notice something like this or have I lost my mind?
I'm on Att. My notification light only for WhatsApp is that strange color. The other ones are the normal blue. Weird.
Your mind is still intact. I have seen this also at times. I wanna say it has to do something with getting notifications like holidays, events like the day certain things happened in time, etc. Can't recall offhand how this got turned on. Will keep looking.
Here's what I think it may be. I am using Sunrise calendar and having it notify for various events (birthdays, holidays, Dr appt, etc). Seems like when there is a notification is when I get the blue/red blinking light.
It may be a function of the phone regardless of, in this case, the specific calendar being used.
Would be interested if others are noticing this also, other than the above posts.
I only get the Red/Blue mixture when I receive an email using the app Mailbox. Others have to be seeing this also.:-\
Okay, so I'm not seeing things then! And I'm coming from a BlackBerry, where we often use different colours for notifications...
You can choose a different color light for notifications on different apps, depends on which app you are using. I do this so I can tell what came in by the light.
Do you have to use a third party app for this?
ElementOrganic
