Verizon Nougat LED Notification Settings?
ziggster
160
3
I updated to Nougat on Verizon yesterday seemingly with no issues. Now I've noticed that the LED notifications are off & I can't find where to turn them on (if anywhere).
Any help would be appreciated.
Edit: Seems that only Gmail is experiencing the LED problem...everything else seems to work.
Sorry for the confusion.
Solved...Cleared data from Gmail app and uninstalled updates. Fired it back up and updated. Now I get an LED notification for new Gmail messages.
I had the same problem and your tip fixed it (thank you for that), but with one issue -- now I can only get the led notification if I also get an audible notification. Before the update, I had Gmail set to give me just the led notification but no sound. Now, if I set my Gmail notification to silent, I lose the led notification. When I change the Gmail notification to something other than silent, the led notification comes back.
Do you get an audible notification with the led notification, or just the led?
I have no led with the native sms app and missed calls or voicemails on my s7. Anyone else seeing this?
In settings> go to> sounds & vibrations> notification sounds> if your e-mail address notification sound is turned off> tap setting to turn it on.
yanis
