Verizon S3 update problem!!
Kayla Jenkins
I no theres an update for the S3 but everytime I click software update it says the status is "not available" and when I click check new, it says "Software update is temporarily unavailable. Try again later." Does anyone else have this problem?
Re: verizon s3 update problem!!
Same here...
Sent from my VS980 4G using AC Forums mobile app
You can also uses Samsung Kies connected via USB to your PC to check and get updates.
I had this same exact problem when JB first came out and I knew there was a update.The only thing that fixed the problem was a trip to Verizon for a new SIM card, no problems with updates since.
s3solnduck
