Verizon s6 edge...10 hrs max after fully charge
dunamis
207
do I have a faulty phone? It always says 10 hrs max.....[
ATTACH=CONFIG]173530[/ATTACH]
I found my google play services consumed a very high % of battery, and most of that due to location services. Once I disabled it the % goes down dramatically and help boost battery life. It sucks but might wanna give it a try until 5.1 comes out
Do you have the latest version of Google Play Services? There was an update to fix this. The latest is version 7.3.29
I have 7.3.29 and I can tell you it doesn't. Not even clearing memory or reinstall
It's not what it estimates, what really matters is how many SoT hours and standby hours it gives you.
With the above information we can't give you any more details, you must use it as you normally do, and keep monitoring those battery stats, once you have at least a half day use, take screenshots and post them here, just go deeper on the stats so it shows the detailed information of the battery alone, not Power Saving Modes and in there enter to screen so it shows the amount of SoT (Screen ON time).
dumpling
