very specific 'audio profiles' question for my D4 w/ JB
big matty
111
Hello,
I use stock phone app, stock text app, and either Touchdown or K9 for email. In my use case for Touchdown I rely on personalized email alert sounds.
Many moons ago I owned a BlackBerry, and to this day I still like the way its audio profiles work. Yes yes yes, I know Android dosent match this up one-for-one and I know that there are apps that try to help... I do use these apps too. I've been using Llama for about a year now to manage my audio profiles. Had been working well.
But now after the JB update it seems my audio profile apps lose the ability to "block" the vibration command. I've found, at least back on ICS, that I need to tell Touchdown to always beep and vibrate, and then the audio profile app BLOCKS what I want, and the end result is as desired.
Does anyone know of an audio profile app that still can correctly manipulate vibrate? Please - no general suggestions of "I've heard of this audio app" because I've been downloading and testing a lot of them...
TIA,
BM
dayssss2
