Vibrate on Tap?
Stwutter
553
Hi. I've turned vibrate on tap on, but nothing vibrates when I tap it...
Can't say I can't live without it, but no matter how much I muck about within the settings, I can't get it to work.
Well, that's weird ! I would say try checking the vibration of your device by putting your device over the the vibration mode see if your device vibrates or not ?? If it doesn't then I would say you may need to walk to the nearest support !
I only ever have it set on vibration only and everything else works fine.
Issue resolved. I just stupidly assumed that it worked by using the scrolling bar. Just realised you have to check a box too....
zeke
