Vibration problem
Peter Van
7
Hi
so basically when ever i select an app, it use to vibrate when ever i select or press something on the screen but now it just does nothing
ive checked if power save is on, but it's off. I know my vibration works because when ever i press my back button it works but now when
i press any apps on the screen it just wont vibrate anymore. I also check if haptic feedback was tick and it is.
Please help asap :(
Peter
Hi
Please help asap :(
Peter
Goto;
SETTINGS > SOUND
Below HAPTIC FEEDBACK, do you have the option AUTO HAPTIC on right now??
It may be a configuration specific to the app launcher you're using. For instance, if instead of the built-in one you are using ADW Launcher, GO Launcher, etc., check their settings for this feature.
i don't have the option auto Haptic feedback i only have "Haptic feedback" in SETTING>SOUND andck it's under system i also check vibration intensity and put haptic feedback to the max
Goto;
SETTINGS > SOUND
tried going to my built in launcher and still no haptic feedback when clicking apps
You want your phone to vibrate every time you open an app?
basically before i had this problem, every time i would press an app, click on a twitter post, press a setting or basically select something on the screen it
would have gave me a haptic feedback but now it stopped all of a sudden
Do you have power save mode on?
Sent from my SGH-I747M using Tapatalk 2
