Hey guys, here's another video with the Verizon silicone case (black) on my Gnex with the extended battery. This one was the best of the three that i've tried with the extended battery.
Diztronics - Fit but was a little snug and sometimes the power button wouldn't respond so quit using that case.
Incipio double case - this one did fit, but there was a slight gap between the soft inner case and hard outer case. It still worked, but didn't like the extra gap.
EDIT - I do like the Verizon Silicone case the best, but just wanted to update that I did send an email to Diztronics letting them know the volume rocker on their cover was a bit soft, they responded within an hour, saying a replacement cover was on the way. . .got it in two days! The new cover is the smoky grey? It's slightly different from the black one I originally ordered, the texture has slightly more grip and the volume rocker is slightly different and works better then the black one. So I would recommend the diztronic grey case over the black, I'm sticking with the verizon silicone as i like the "grippyness" a bit better and it is slightly thicker which gives extra piece of mind as far as protection. But Diztronics customer service is pretty f-ing awesome so kudos to those guys and the new case is much better!
