• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Voice assistant won't turn off and emergency mode is stuck? S7
A
AC Question
my phone S7 seems to be stuck with voice assistant on. I can't get it to do anything. Pattern to unlock is difficult- phone vibrates while trying to draw pattern, on 3rd or 4th try will unlock if pattern is drawn slowly and with heavy finger pressure. screen is not responsive- slow and requiring long hold and double tap to make selections. Icons are big, cant get to settings as they are on another page and screen won't scroll.phone gets very hot.
anon(9602380)
778
Welcome to Android Central.
I suggest trying a hard reset. Hold your power and volume down button at the same time till you see it restart. Then let go of the buttons. Hopefully this will help with your issue. If not then my other question to you is did you recently install any new apps? If so delete it and do a hard reset. Thanks!
philoldguy
3
just go to apps and go down to talk back which is voice assistant force stop it and it will stop and screen icon will go away too yea sounds too easy but it works or you can tap and tap 2 times to turn off voice assistant under vision this is the easy way took me several hours to find the way too and yes my s7 now lets me control it
philoldguy
3
go to apps and then talkback this is voice assistant force stop it and it will stop and icon will go from home screen too good luck
Pollyt
Husband, after spending most of the morning trying to get out of voice assistant, finally did it by using two fingers for every swipe and press. It worked for him so good luck with your two fingered manoeuvres..
D-roids
Pollyt,
I hope you see this - thank you so much for posting this. I though my phone was toast as I couldn't get past the lock screen to turn the damn voice assistant off!
I would never had know about the two finger method so I am really very grateful!!
