Voice Input Button not working anymore (Fresh 0.3)
helfire#AC
17
Have Fresh 0.3 installed and Swype beta.
My Voice Input Button on the keyboard isnt working, dont know where to start to debug, any ideas? (not on swype/htc_ime/stock) tapping it just does nothing.
Thanks
It is by design. He turned it off. Read through the change log. Small possibility I am thinking of a different ROM.
Voice Search (I am constantly hitting it on accident while using my phone with one hand. I have also had issues with it killing audio on the phone). *
Ahhh... :) oh well, just use it usually to show off.
Thanks for the quick reply
If you use a file manager to find the folder in your SD card labeled something like Fresh's uninstalled apps you can reinstall it.
I just flashed fresh today and I'm loving it so far! Best battery life I've seen yet!
Look on your SD card and it should have a folder with APKs and its of the last ones I think it says voicesearch
He posted the link to removed apks with his ROM for those that wanted them. VoiceSearch.apk attached below.
Bride96
