Voice notification of texts and phone calls on SG6?
Katedelic
3
I can't find this function. Is it not available on the 6? Is there an app I can install that does it? Any help is appreciated. Just got the phone yesterday. :cool:
Welcome to Android Central! To clarify--do you mean you want the phone to give you spoken notifications that you have a text, or spoken caller ID notifications of who's calling?
I would like to know if the S6 has the spoken caller id notification. I can do it on my LG G2 but I can't find it on The Samsung S6.
Open the Phone app, tap More>Settings>Answering and Ending Calls. Is there a Voice Control box? Make sure it's unchecked.
Oh, how silly of me. I thought you wanted to get rid of that feature, not add it!:p
I think what you're looking for is the CarMode (for Galaxy) app in the Galaxy App Store.
You may find my new app useful.
search for "speakify" on the play store to get it (I'm not allow to post links - I'm new :))
Well I found the setting finally. It is in Google TalkBack which if you turn that on it talks every time you do something on the screen so that is annoying so I turned it off. I just want it to announce the incoming calls. Thanks for the recommendation SDroid but that app seems complicated. Maybe I will try to figure it out later.
Did you try looking for Car Mode in the Galaxy Apps Store, as suggested by galaxyfive?
yes not exactly what I was looking for. I found an app in the app store called Talking Caller ID that works exactly how I want it to work and was easy to figure out. Thanks for all of the suggestions!
Richie Q
