voicemail issue after 2.2
csm7882
Ok, so I was looking all over the forums for a similar situation, but was unable to locate one.
After I updated my Incredible to 2.2 (around 9/3/2010), my phone says that I have 1 voicemail waiting (from that same date). Yet, when I login to my voicemail it says that I have no messages.
I do have Google voice. Does anyone have a solution? Or the same issue? I'd like to think that I'm not the only one, but then again, my mom did tell me that I was special as a child so it might be my luck.
I would try going into settings>apps>manage apps>running apps>Google voice then select clear data. You will lose all your settings and stuff so you will have to sign back in but this should get rid of that message.
BrainOne
