Voip using CM7
Eollie
1,534
258
Ok so I recently started using the full potential of sip/voip.
I had everything working and Friday night I did something and my phone crashed.
I had to reset to a backup I had made before I had everything working.
So yesterday i spent a good three hours trying to get it all setup like it was before. Only I cant get it to register with pbxes.org. Everything is the same I followed the same guide to make it work and it still fails to register.
I tried using sipdroid thought maybe it was a bug in my rom. Still wont register. It tries then says "Account registration failed:(transaction terminated); will try later.
I dont know what happened but are any of you guys experiencing this?
The password you use for your extension at pbxes.org is not the same as your pbxes.org account password.
Log into pbxes.org, look up your extension, and get your password. This is usually the problem if you used sipdroid to setup your account for you. It automatically creates the password for you.
I setup everything on my own.
The option to have sipdroid do it has been removed since pbxes is not requiring people to have a premium account to use the gvoice truck service.
kikoparra112
